Salta al contenuto principale
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 Domande Visualizza tutte
Logic board shorter screw goes where?
After removing the logic board screws to lift the board a bit to lever off the stuck-on battery I noticed that one of the screws was shorter than all of the others, but it was not obvious which of the screw holes it came from. Reassembled with a new battery and the screws inserted at random everything works so far. Was I lucky or did it not matter?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
fnifixit, both ;-).I just checked one of mine and it really does not matter on this model. Hope this helps, good luck.
Punteggio 1
Aggiungi la tua risposta
fnifixit sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 199
