Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
654 Domande Visualizza tutte
replace ssd on this iMac 20"
I want to replace my old hard drive with a new ssd.
I can remove the old and insert the new inserting it with this adapter or not?
http://www.amazon.it/OCZ-SSD-3-5-Adaptor...
thank you all!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
looks like it should be low profile enough to fit in the same space as the regular HDD
Punteggio 1
I have replaced my 320HHD in my 2210 Imac with a 240GB SSD using the mounting plate that came with the SSD. There is plenty of room in the drive bay to instal the SSD. Mount the SSD in the mounting plate, hook it up and using double sided tape I mounted the plate vertically in the drive bay. Closed up the Imac and it has worked fine ever since.
Punteggio 0
Aggiungi la tua risposta
Elvio sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,112
