3194 error while restoring
when im trying to restore my iphone 4 the itunes gives me 3194 error, i did delete those lines from the host file but it still the same? what shud i do?
Questa è una buona domanda?
You can use tiny umbrella to get your shsh blob save onto your computer and the then use redsnow the latest one to restore it then everything should be find as you mention you edited the host file so i pressumed you know what you are doing.
If you need an explanation how to do it then let me know i will explain you and as you can see above if you use another computer will do the trick
Thanks
we often get the same error so we just go to a different computer using a different itunes and 99% of the time it will work. Just plug it in and do the same process.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 766
1 Commento
Make sure iTunes is current up to date version.
da Brad
