Salta al contenuto principale
iMac è la linea di computer desktop Apple all-in-one.
8366 Domande Visualizza tutte
Can I remove a cd label from the drive?
I (stupidly) put a cd in to burn and I applied the label first. Ugh! After a few minutes, I got an error message saying there was a problem with the disc. It then, automatically ejected the disc.... with no label. Now, it will not accept a disc. When I put another in, just to check, it goes all the way in, but then ejects immediately. Is there a way for me to get the label out myself? Has anyone had this issue? Please help, I certainly don't want to spend hundreds on parts and labor.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Which model of iMac do you have ?
You will probably open your mac and drives to get out the label...
da
It is the iMac Intel 24" EMC 2267
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Ok ! So you have to follow the procedure for changing the drives.... without changing it.
Sostituzione Unità Ottica nell'iMac da 24" EMC 2267
And then open the drive to take out the label...
Optical Drive Disc Removal Technique, or Foreign Object Removal
If this answer was helpful please remember to mark it accepted.
Immagine Optical Drive
Guida
Difficoltà:
Facile
1 - 10 minutes
Immagine iMac Intel 24" EMC 2267 Unità Ottica
Guida
Difficoltà:
Moderato
Punteggio 3
Aggiungi la tua risposta
Jennifer Neville sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 341
