Oil leak near timing chain
Have and oil leak near oil pan and harmonic balancer in my 2007 unlimited sahara edition wrangler
Questa è una buona domanda?
Could be the oil pan gasket. Spray it off with some engine cleaner and investigate where it leaks from. take a couple of pictures and post those on here.There is also the oil pump that is in the front cover, driven from the front of the crankshaft. Oil passes in and out of the front cover through the timing cover gaskets which may have failed. A failed front crank seal will usually fling oil off the damper and soak the area.
Oil consum engine 08 wrangler
Sergo Saintil, I suppose you mean to ask a question:-) What exactly do you want to find out about?
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 21
Tutti i Tempi: 2,398
2 Commenti
what engine is it,4.0?
da oldturkey03
3.8 v-6 engine
da Miguel Guebara
