Salta al contenuto principale
Versione migliorata del Nintendo Game Boy Advance, l'Advance SP è stato rilasciato il 23 marzo 2004 in Nord America, con una struttura quadrata ed un design a conchiglia.
163 Domande Visualizza tutte
How do I know if my SP is getting charged?
How long does it take for a Game Boy Advance SP to charge and does it have any lights that stay on or flicker to indicate charge? because when I plug in the charger to my SP an orange light will flicker only once then turn off. Is my SP broke?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Rosie Pacheco, sound like you are either not getting a charger, or your battery is no longer accepting a charge. Check your charger with a multimeter to see that it does supply power. Take the back cover off to expose the charging port. With the charger plugged in, you should get around 6V at the port. Then check the voltage on the battery ports and see what you get. If so, it may be time to change the battery and then re-evaluate. Check this video on how to change the battery. Hope this helps, good luck.
Punteggio 2
Aggiungi la tua risposta
Rosie Pacheco sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 66
Tutti i Tempi: 10,147
