Heat blows from dash vents only not floor or defroster
I have a 2007 Dodge Grand Caravan. The dash vents are the only vents that work. It blows hot air so I don't think there is anything wrong with they heating system. There is just no air from floor vents or defroster. Years ago this was controlled by vaccum lines, but now everything is electronic. Any ideas?
Questa è una buona domanda?
3 Commenti
Needs computer recalibrated
da Charlie Spain
I have a 2010 Honda CRV with the same problem and I’m having a hard time finding a solution would disconnecting the battery also work to reset the computer to make it work the right way again .
da Robin
you more than likely need to change the blend door motor for the defrost and feet. it will require the dash to be removed to get to these
da nathan chenweth
