Replace Superdrive with 2 hard drives?
Is it possible to replace the superdrive with two 2.5" hard drives? Just want to use duo SSDs to replace cost.
Questa è una buona domanda?
Ronnie - You only have two SATA ports in this system both are in use (current HD & Optical drive).
So you'll have to decide which device you are going to swap out. You can either take the optical drive out to install a second HD or SSD or take the current HD out and put in a SSD.
There isn't enough room or power or I/O connections to supply a third device.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,571
