Do you have any suggestions on removing stripped screws?
I have stripped three of the 1.5mm screws securing my trackpad to the top case. Despite applying sufficient pressure, the #00 screwdriver I was supplied with stripped the screw heads like butter.
My question is, does anybody have any suggestions for removing stripped screws? My first thought would be using long nosed pliers to grip the edges of the screws, then rotate.
As an aside, does anyone have a source for obtaining these screws? I would obviously need replacements.
Questa è una buona domanda?
1 Commento
If you have a multi-tool with a carbide blade or a grider with a thin cutting blade. Cut a straight line across the head and use a flat head bit on a drill to reverse it out. If that doesnt work, cut the head off and drill it out. If it is a threaded hole, tap the hole with a tapping kit and get a new bolt to match the size. Hope it helps.
da zachary west
