Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
iPod 4th generation forgot password
i forgot my password and i cant log in please help me?
Questa è una buona domanda?
Punteggio 31
1 Commento
I Cant do none of that because i cant use the computer how so you reset it without that cause i locked myself out
da
Aggiungi un commento
8 Risposte
Soluzione Prescelta
jordan goulet,here is my answer to the same question "you can restore the device on the the same computer that you normally use to sync your iPod. Put the device into DFU mode, then open iTunes. Select your iPod in the sidebar, and click restore. This will restore the device to factory setting but it will DELETE ALL YOUR DATA if you have not backed it up, it will be lost. You put your iPod in DFU by
Turn off iPod
Hold power button for 3 sec
Hold power and home button for 10 sec
Continue to hold home button until iTunes pops up a message telling you that it has detected an iPhone in recovery mode. The screen should remain black. This should reset your password. Hope this helps, good luck.
Punteggio 9
6 Commenti:
by data do you mean pictures?
da
Itati Vazquez pictures, music anything that does not come with an iPod.
da
this dosent even work
da
this is so fAKE'
da
@joshuaniib what makes you think that this is fake? You do need to consider that this was 5 years ago and iOS has changed and things that worked at that time may not work at the current time. Nothing fake about it!
da
Mostra 1 altro commento
You don't actually need the same computer that you've used in the past. I've done a lot of these on my computer and they were never hooked up to that specific computer before.
Just open iTunes on any computer.
Turn your iPod off.
Hold down the home button while plugging in the cord to connect it to the computer.
Keep holding it down until you see a cord on your iPod.
iTunes will ask you to restore, do so.
You're all set, but you're going to loose all your data.
Punteggio 6
4 Commenti:
It was amazing
da
Thank you for this helpful info.
da
thank yyyoooooouuuu
da
uh it did not work to open itunes you need to sign in
da
http://www.youtube.com/watch?v=5uT8Utk5T...
Punteggio 1
You will need a computer to log in your iPod in it than you swipe to the passcode page than you press and hold the home button and a few seconds the apple sigh will pop up than you let go the power button but you keep your finger on the home button than open up iTunes on you computer that finish the terms and conditions and few thing will pop up on you iPod and yeah
Punteggio 1
This works with any ipad, iphone, ipod.IOS.Have a computer with itunes on it and plug the usb end into the computer. Shut the device off by holding the sleep/wake button until prompted to shut off. Wait 30 seconds because it is still on. Hold the home button then plug the other cable end to your device in, keep holding the home button. On your computer it will tell you that this device is in recovery mode or it will give you 2 options: restore or update. Click restore. It will tell you to "update and restore". Click to do so. There will be a bar loading on the top of itunes. Then follow the onscreen direction.
Punteggio 1
Turn on iPod wen the iPod is ready
Punteggio 0
how to unlock my ipod 5 touch
Punteggio 0
1 Commento:
da
So….my home button is actually broken….now what?…
Punteggio 0
1 Commento:
Your going to have to replace the home button before you can fix the iPod. There's 2 parts that make up the home button. The button itself and then the flex cable that controls it. It's about $5 for each part on ebay. You won't know if it's the cable until you open it up. Good luck in your adventure. It's an easy fix.
da
Aggiungi la tua risposta
jordan goulet sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 45
Tutti i Tempi: 62,265
