Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Domanda Chiusa
Why remove battery when replacing vibrator?
Just wondering why it says in the guide that you should remove the battery when replacing the vibrator?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
you should try to remove the battery on any repair. avoid having electricity in the bord while you are working on it...
it's just safety thing, but i think there are a lot of repair guys who don't have time enough to unplug the battery first and replace the vibrator anyway ;-P
Punteggio 2
1 Commento:
That's totally right ;) time vs. safe repair
da
removing the battery prevent power from running through the motherboard, so less chance to short circuit the board, just to play safe, disconnect the batter or power supply, cheers!
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 430
