Can I use my LCD TV as monitor?
Can I use my occasionally my LCD TV as monitor with my iMac?
Questa è una buona domanda?
Y ou need a mini dvi to hdmi connector such as the StarTech.com Mini DVI to HDMI Video Cable Adapter for MacBooks and iMacs - Video adapter - Male Apple mini-DVI to FeM 19 pin HDMI Type A
This iMac came before mini DVI
Wrong again rab. Please note this was the start of the Intel machines. Thanks for another downvote.
http://support.apple.com/kb/ht1463#30172...
iMac (Early 2006)
The iMac (Early 2006) was introduced in January 2006. This computer has several features that distinguish it from the iMac G5:
A 1.83 GHz Intel Core Duo processor with a 17-inch screen, or a 2.0 GHz Intel Core Duo processor with a 20-inch screen.
Comes with an ATI Radeon X1600 video card using PCI Express.
Comes with a mini-DVI video out port.
My bad, mixed up DVI and DisplayPort
If DVI to HDMI is too expensive for you then DVI to VGA will work as well.
The cable I recommended is $12
$12 is a bit more than 37 cents, more options is always better for people with unknown budgets.
In that case, you can use an adapter such as this one to connect the DVI port from your mac to the HDMI port on your TV.
This type connector was available for some AGP and PCI video cards used in the G4 towers and Mac Pros.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,831
What connectors does it have?
da Nick
Does it have HDMI or DVI input?
da rab777hp
If you do not know then tell us what TV you have, model etc., and we can research and tell you.
da rab777hp
I have Samsung LCD TV and it has two HDMI port and one VGA
da Martin
