Salta al contenuto principale
After replacing LCD, the screen lights up but no picture
I dropped my MacBook air and broke the left hinge, Shortly after that my screen was turned a blue hue. I opened it up and found the LVDS cable was frayed and then my screen went from all blue to completely large pixels. I replaced the LVDS cable but when I reboot the screen lights up but no image. I can get an external screen to work. Going into displays only shows the external display. I purchased a new MacBook air top complete with wires attached but got the same issue. Is my video controller in the laptop fried?
Questa è una buona domanda?
Punteggio 1
1 Commento
I noticed you never got an answer to this. Are you still having this problem?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Since the external monitor works the GPU and logic board are fine. The problem is all in the display. With the unit showing no internal display I would go back to the display data cable. Also how reliable was the display supplier?
Punteggio 2
1 Commento:
Did you work this one out? Similar issue here...
Punteggio 0
Aggiungi la tua risposta
martin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,871
