Salta al contenuto principale
Why can't I save a game?
When I first bought the official GAME BOY micro games, They used to work well and finally save well..
But as the time passed by, The saving feature totally stopped..
How do I save my games? Starting the game all over again is very boring..
PLEASE HELP
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Depends on the games you are playing I would venture to guess that the internal battery in the game carts have died, so they will save to the cart but once removed from the system or powered off they loss their data. Typically they use a coin battery and just check the voltage and such once you extract it and pick a new one up and replace should fix the issue.
Punteggio 0
1 Commento:
btw. Gameboy Advance games use CR1616 clock batteries to save their games which can be bought on Ebay. You do need to solder to change the battery (some also use flash memory, but those doesn't die/run out)
da
Aggiungi la tua risposta
IamRamCena sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,694
