Salta al contenuto principale
A compact digital camera released 09/15/2005.
sd card won't come out of camera
The sd card is stuck in the camera. Any ideas as to how to get it out. Have tried tweezers and it still won't come out keep pushing but no luck getting it to pop out as it normally does.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi, I think the spring mechanism might be jammed. What u need to do is push the sd card down gently and gently turn the card, and try to pull the card out. The key is patience and be gentle. Write back on what u did. Good luck.
Punteggio 1
1 Commento:
thanks it worked
da
I have the same issue & I got its solution later. So i can help you.
Punteggio 1
Aggiungi la tua risposta
Molly sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,061
