Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
Domanda Chiusa
My water damaged iPhone 4 won't restore!
Not long ago I dropped my i phone in a cup of tea, it messed it up pretty badly. After changing the battery and cleaning it up a bit it now seems to work perfectly fine...UNTIL. It works fine until I attempt to restore it. It is currently stuck in safe mode and all I want to do is restore it.Whenever I try i comes up as an unknown error (-1) or (9). I've since been told that thi is a hardware problem. So I'm interested to know i anyone knows how fix this...a sort of DIY hardware fix.
Let me know,
cheers
Questa è una buona domanda?
Punteggio 0
2 Commenti
By any chance is the iPhone jailbroken?
da
no it's not jailbroken Danny
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Take the logic board out and clean it thoroughly with isopropyl alcohol and a cotton bud.
You will need to remove the metal shields covering the processor and what not - corrosion hides here and causes all sorts of mischief.
Punteggio 2
1 Commento:
Hey craig thanks for your reply. I have another iphone 4 that has a blocked IMEI number on it but works just fine. So i'm thinking of swapping the logic board from this phone to my phone...is this a better option than just cleaning the water damaged one?
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,562
