Salta al contenuto principale
The Motorola V710 is flip-phone with internal and external high-resolution color screens and expandable memory.
Charging Jack Won't Charge!
A common problem with v710's (and actually all v series dumb phones) is that when you plug them into the charger the phone either won't charge or they charge intermittently, depending on how good the connection is to the charger plug. I have one v710 that won't charge at all and another one that only charges if I put a great deal of pressure on the connection by hand. As soon as I let go, it stops charging. Does anyone know what the problem is and is there a known fix for it other than just getting another phone?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Henry Fiddler, check the charging port solder connection, It is possible that they are loose and a simple resoldering may resolve this. If not, then the best way to fix it would be by replacing the port. Use this guide to work on the logic board, the charging port is available at places like this. Hope this helps, good luck.
Punteggio 0
Clean the charging port contacts with a wood toothpick. I do this monthly, and it always works.
Punteggio 0
Aggiungi la tua risposta
Henry Fiddler sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 605
