Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
touch screen inoperative on top row of qwerty keyboard
I changed my battery. The phone powered up as expected, but the touch screen on the virtual keyboard's top row is inoperative. Also it will not accept a charge from the charger. Should I disconnect and reconnect all straps and connectors?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi, you best option will be to disconnect very carefully, as when I did my battery change the no 7 connector got broken, that is, the connector was still seated on the board and the cable came loose. So, very carefully undo all the connectors, display, touchscreen and earphone, then look if there is any damage. Reconnect and see if everything is ok. Write back how it went. Good luck.
Punteggio 2
Aggiungi la tua risposta
Doug sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 445
