Car wont run without being jump started
Nothing happen when we turn the key
it doesn't even do anything eccept for the door on the dash trun on
Questa è una buona domanda?
JumpStart the car, disconnect the battery, if it stays running, alternator is most likely good which means you need a battery. If the car dies, alternator is bad and change it.
please note that if your alternator is out, it can take the battery out as well due to the fact that a battery does not handle being flat dead Well. So if you must change the alternator, there couldold be the same problem if the battery dies. So after you change alternator and it still will not start without a jump but runs fine without battery, change battery too. (10% chance in my experance)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 440
1 Commento
Have you changed your battery yet? Have you cleaned the battery cables?
da oldturkey03
