Salta al contenuto principale
Conosciuta come ''PS2'', è una console per videogiochi di sesta generazione rilasciata per la prima volta da Sony in Giappone nel marzo 2000. Negli Stati Uniti è stata introdotta nel 2000 con il modello SCPH-30000. La riparazione di questo dispositivo richiede solo strumenti comuni, ma può essere complicata.
199 Domande Visualizza tutte
Why has my screen changed to black and white
For some reason the playstation 2 is in black and white only. We tried to plug something else into the connection on the TV and it was fine but the playstation is still only black and white.
Questa è una buona domanda?
Punteggio 10
6 Commenti
i have a similar problem with my ps2, however I bought a aftermarket cable, would this cause it to show black and white?
da
after playing game for sometime by pendrive graphics become un-understandable why???
da
Thanks a bunch, it works!
da
I have this problem, but I have the slim version, is there a difference? and I have a weird tv, that does not have the normal yellow, white and red holes for the cables, but video works, and sound just fine, but no color.
da
Everytime i play f1 2006, richard burns rally, and a few other game on my ps2 my tv screen just black and white but if i play other games like gran turismo 4 original japan, and nfs underground 2 it has colours.
da
Mostra 1 altro commento
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Tara, depends on how you have your PS2 connected. If you are using the component cables, check in the system settings and check if its in regular RGB. If you use the regular Yellow, Red and White cables, it should be in RGB mode.
Punteggio 3
8 Commenti:
this didnt help me but my PS2 is in RGB mode already
da
Is ur ps2 modded
da
Now it won't let me view system settings it will only play movies n is still in black and white now I can't change it back from RGB that what's it normally was
da
i needed to change my tv to the AV channel instead of the component channel also to fully fix this issue
da
Thank you halo117ish
da
Mostra altri 3 commenti
Risposta Più Utile
I was having the same problem but I changed my input from component to AV and that worked.
Punteggio 11
14 Commenti:
I did exactly what you said and it works! Tq tq tq
da
Me too!!! Thanks a bunch! Putting on AV worked :D
da
Thanks a bunch, it worked!
da
How can i change my input to av ?
da
Just go to input it should be right on your remote for the TV and then you should see AV as one of the options then push the up or down arrow to go to the AV option the once you are on it the push select that's the button that says select on it yeah you just push that button.Thats it.
da
Mostra altri 9 commenti
This one is problem on the HDTV with tons of features in it. First go to your TV's settings and open option (in my case I'm using 50" Sharp Aquos 1080p), if you don't find it check something similar to above. Then, you want to change the "Input Select" from "Component" to "Video." This will change the color system automatically as "Component" label are for newer devices and sometimes can't cope with older devices such as PS2. After you've done it you might see the "Colour System" option and that's where colour calibration option exist. My TV sets itself to NTSC 3.58 where as the component shows 480i(with monochrome color).
Punteggio 3
3 Commenti:
Thank you this helped a lot
da
That was exactly what fixed my issue.
thank you!!
da
Omg thanks so much
da
My tv is LG and it’s showing black and white for my PS2
Punteggio 0
2 Commenti:
@faousyjami27127 have you followed any steps in the given answers?What have you tried?
da
I had the same issue. You need to use a different input on your tv.
• Check the system settings: Make sure your PS2 is in RGB mode
• Check the cables: If you're using the yellow, red, and white cables, make sure they are in RGB mode
• Check the composite cables: Make sure they are not plugged into the component input
• Check the TV inputs: Different inputs will provide different levels of image quality
• Check the HDTV's operations manual:
Look for a game mode setting or instructions to turn off digital picture enhancements
• Adjust the contrast or sharpness settings:
This may help reduce jaggies
da
Aggiungi la tua risposta
Tara sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 37
Ultimi 7 Giorni: 296
Ultimi 30 Giorni: 1,285
Tutti i Tempi: 246,673
