I would also like to thank Chris for his answer, but can't figure how to add under his post! My experience was a little different and may be helpful to others. The iPhone 4S of a friend needed the screen replacing and it is OS5, but the date fix worked. I have never done this before or even owned an iPhone. I followed the guide here
Sostituzione schermo iPhone 4S
which is complete except it doesn't mention the front camera surround (a clear plastic ring with a bit needs to be prised off the old screen and put back in the phone body and the new screen put on from top so the surround thing doesn't fall out.
I am very meticulous and felt I did a good job, but got a continuous Searching. Telstra couldn't fix it! They did the sleep reboot and other stuff and wanted to sell a new phone! Going into settings general date&time, turning it to manual, setting it to current date & time, ejecting the sim card and reinserting it, turning airoplane mode off then on got it sorted. The last step was probably only needed to recheck as where I fixed the phone there wasn't good enough signal to pick up but going outside then turning aeroplane on & off saw it sorted.
I did as a "by the way" also connect to my wireless system before doing the above, this was just to see if that worked or not, but I was connected to wireless throughout the above procedure, doubt it is important but stating for completeness.
The unusual aspect to the above is this was an OS5 phone whereas others say it is an OS6 issue, it seems it is really a bug that has been carried on from earlier!
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
5 Commenti
the male connector came of the circuited board? That could most certainly explain why it is searching
da oldturkey03
Isn't that for the wifi? so I mean the small thing which is under this thing: http://images.anandtech.com/doci/4971/4S...
How can I fix it?
da Mittchel
It'll help if you post an image of the actual broken part, including the board.
da oldturkey03
You won't see anything on the picture. Though I can explain.
On the 4S you've the wifi antenna which is under the screw on this picture: http://images.anandtech.com/doci/4971/4S...
And you click the antenna ONTO the motherboard. Well, the thing where it needs to be clicked in came off the motherboard and is still attached to the antenna.
But that doesn't make any sense why its keep saying searching and doesn't popup my pincode screen..
da Mittchel
Does anyone know what causes this problem?
da Mittchel
