Salta al contenuto principale
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Domande Visualizza tutte
Domanda Chiusa
Can I replace dead superdrive with a SSD hardrive?
I have a Model A1224 / Mid 2007 / 2 GHz Core 2 Duo processor / 4 Gigs Ram ver 10.6.8
Can I replace my dead optical superdrive with an SSD drive?
What kind of enclosure do I need and can I use the
existing cables in my iMAC to achieve this?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Here is the guide to replace the optical drive with a hdd or ssd.
Installazione dell'SSD Dual Drive nell'iMac Intel EMC 2133 ed EMC 2210 da 20"
Your iMac will need a ATAPI enclosure like this one:
http://www.pro-battery.com/battery-detai...
If you take that info and look for the equivalent on iFixit this is what you will find:
[prodotto collegato mancante o disabilitato: IF107-079]
Punteggio 2
4 Commenti:
Thank you Jay for your info
Can you tell me what kind of enclosure/caddy I need and can I use the
da
da
I do appreciate the time you took to answer my question.
But your link says it's for a mac Mini not a Mid 2007 / 2 GHz Core 2 Duo processor desktop. I'm still stuck with no answer.
da
I just edited my answer and added links to the proper enclosure. I did a quick search on your iMac and found that the one in the guide will not work as its SATA and not ATAPI.
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 9,318
