Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
3033 Domande Visualizza tutte
Damaged battery after lcd replacement?
Yesterday I put in a new LCD replacement for my iPhone 4s 32 gb. The screen works great and everything else works as well after reassembly.. HOWEVER. My battery started to drain very rapidly once I powered on the phone. The phone was also warmer then usual.
It seems the battery only charges when plugged in and powered OFF! If it is on and plugged in, the battery will drain but at a slower pace.
Do you think I damaged my battery? or shotty reassembly that could have caused this problem? I was thinking I would try and replace the battery as a first step of trouble shooting.
Thanks in advance for any help
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Risposte
Soluzione Prescelta
The first thing I would try is opening the phone and making sure that all of the connections are solid.
If all the connections inside the phone are still good, and you continue to have the same problem with the battery, then I'd recommend trying a new battery to see if that solves the problem. Good luck!
Immagine iPhone 4S Replacement Battery
Prodotto
$16,99
Punteggio 2
Make sure you have the Ground that is connected to the battery plugin with a screw. i had the same problem forgot to put the ground back in and battery drained rapidly.
Punteggio 0
Aggiungi la tua risposta
jay sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,682
