Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2520 Domande Visualizza tutte
Sim Tray material short circuits?
Hi,
I have a few questions about the SIM tray and hope that you can answer it to me.
1. Which material is this tray?
2. Is there any coat in the SIM area?
3. Is the tray conductible?
Backround to the questions.
My Provider an't deliver Nano-SIMs this year. So i cut my SIM to the Nano size. But not the SIM is a Full Chip SIM with no plastic frame.
Now i have the question if i could have short circuits and the sim is not working?
In my iPhone 4 with Adapter the card works fine.
I hope you can help me and a few other users.
Thanks
André
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Risposta Più Utile
the material is Ti-alloy, so it can be conductible. the sim card should be surrounded by plastic for fear of short curcuit
Punteggio 1
I had this conductive sim tray problem with my iPhone4.
Solution is to use a thin coating of nail polish between the overlapping areas between the sim and the tray.
The nail polish, (clear coat/nail hardener -best option) works as an insulato, blocking conduction between the sim and the carrier.
Avoid lathering the nail polish, only a very thin painted coat is necessary. Make sure any excess nail polish is scraped gently away from the sim or sim carier. Too much polish will prevent insertion of the sim carrier back into phone, any excess left can flake off and float around the inside off the phone and may cause problems.
Do not cover the portion of the sim card that needs to connect with the contacts inside the phone.
Likewise if you have one of the early iPhone4 that had the attenna problem, you can paint the aluminium edge with polish thus preventing your fingers shorting out the attenna/reducing signal. This means you can use your early iPhone4 without a bumber case. Later iPhone don't have this problem.
Punteggio 0
Aggiungi la tua risposta
CSchnuffi5 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,995
