Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2201 Domande Visualizza tutte
iPhone thinks there is a sim, when there isn't?
Hi, I just repaired my iPhone screen, and I have done a few before with no trouble, but this time once I had put it back together, it is always searching for reception, but never finds it.
I tried restarting, taking the sim out etc but even without a sim, it doesn't say 'no sim' it still says searching.
Can anyone tell me what is going wrong and how to fix it?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Not totally a apple head here but i do know the iphone 4s has GSM (sim card) and CDMA cellular. i think this plays a role in this.
check your phone settings, And or a restore.
Punteggio 1
Risposta Più Utile
Set the date and time manually to the correct values and then restart your phone. Worked for me :)
Punteggio 2
I've got the same problem.. No one with a helpfull answer for this? Please
Punteggio 1
1 Commento:
Well, found a solution to this problem.
After changing three screens on iPhone 4S with iOS6. All three with this problem.
The solution I found: Insert the sim before you turn on the phone. Then connect the iPhone to the WiFi. Take the sim card out, and put if back in ;)
Hopefully this will resolve the problem.
da
Your problem could come from 3 sources.
The first one is a software problem: just try to make restore with iTunes.
The second one could come from the sim reader commutator. If this commutator doesn't make contact, the iPhone will think that there is a sim in your slot. So you have to join them together. And after, you have to check if it's separates when you put your trap inside.
The third one is: you haven't properly plugged your antenna cable on the antenna connector.
Punteggio 1
1 Commento:
Thank you so much for the second option, I know it's a very late reply, but this helped me SO much. After getting water in my iPhone 6, I thought the SIM slot had stopped working! Thank goodness for this otherwise I would've thought I needed to desolder and resolder things to fix it! It finally recognized when the SIM was and was not in the slot. Thank you so much!
da
Aggiungi la tua risposta
Ben sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 6,787
