Salta al contenuto principale
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
150 Domande Visualizza tutte
Is 'digitizer ribbon cable' of nexus 7 replaceable?
I have accidentally cut digitizer ribbon cable of Nexus 7, can it be replaced?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Assuming this is what you cut, you should be able to replace it.
Otherwise you might have to replace the whole display assembly, but I would try the LCD cable first before replacing the whole display assembly.
Punteggio 2
2 Commenti:
Thanks for your response =), thats not one which I broke, but I was able to get my cable repair from local market.
da
Hi Naveed, did you get the guy from the "local market" to replace just the cable? Mine got pulled off as well and as far as I can see, the ribbon is stuck to the digitizer by some sort of adhesive. Not sure how that works with establishing electrical connections though.
Does anyone know how I can reattach the digitizer ribbon?
da
Can be purchased here
http://www.ebay.com/itm/300829794936?ssP...
Punteggio 0
Aggiungi la tua risposta
Naveed sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 5,334
