Salta al contenuto principale
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
549 Domande Visualizza tutte
Mower starts but won't move.
Mower turns on but will go neither forward nor backward. Just had it serviced at 25 hours last week. The pull knob for pushing the mower is not engaged. It is in position for the mower to be self propelling.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
check and see if the “axle key” are still in
Punteggio 0
1 Commento:
check to see if brake peda isl released
da
There is a vacuum hose going from the front to back on the YV 4000 Craftsman . It rides above one of the pulleys on the deck (left side) and the hose can be cut into by the pulley. You might replace the hose (or tape it up) then use a wire tie (not too tight) or something to hold the hose up.
Punteggio 0
Aggiungi la tua risposta
Allison sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,903
