Why does my optical drive has no electrical power?
I upgraded my iMac 24" Intel Core 2 Duo, 2.16 GHz processor with 2 GB memory with new optical drive. Yet when I powered up the iMac the optical drive had no power and not recognized by computer. I double checked the power and ribbon connector and seemed to be in place. I replaced the old drive that was working before removal and it did not work either..... what should I troubleshoot for in this reinstall?
Questa è una buona domanda?
4 Commenti
Just to be clear here the original player had stopped working which is why you put the new on in. Since then you tested the older player and you found it was OK. If this is correct you likely have a power supply problem. With a volt meter check your 12 volt lines from the supply I think you'll find they are dead.
da Dan
Thanx for responding Dan. I upgraded the old drive that was working at the time of removal. I installed the new drive and had no electrical power to the drive. Troubleshooting, I reinstalled the original apple drive that was working before removal and it too had no electrical power. Could it be a defective drive plug and ribbon connection?
da Fred
Dan, thank you for responding. I did exactly what you said... pulling the ribbon cable without releasing the plate. I released the plate to reinsert the ribbon cable but had to pull from the socket to try again. Upon releasing that very delicate plate it came all the way out of socket and broke the right side release tab... so I'm in a little pickle now and a little frustrated...because failing is not an option for me. Is it possible to replace that release plate/or is buying a external optical drive/burner the only real option now?
da Fred
Sorry to hear the connector is broken. Yes, you could use an external CD/DVD player or burner the I/O will be slower than the internal unit. Make sure you get at least a Firewire case for your DVD unit you bought, if you can wait a bit you might find a Thunder Bolt unit which would be ideal if you have a newer iMac that has a TB port. USB will be the slowest (USB 2.0). Apple is starting to roll out USB 3.0 on the newer Mac's but I don't know if any of the USB 3.0 burners/players have the needed Mac drivers yet (and that doesn't help you here). Lastly, put the older optical unit back in and bring it in to a Apple Store genius bar. I wouldn't tell them anything other than the unit stopped working (limit what you say, don't lie if they ask). See what they tell you the cost of repairing your system. Good Luck!
da Dan
