My front bezel won't snap back on?
I'm having trouble reattaching my front bezel. The two plastic "hooks" that snap into each slot in the bezel frame keep bending downward. I bend them back and try again, but still with no prevail. I'm afraid they're going to break if I keep trying because they're plastic. Is there a trick to popping them back in? I'm not sure if this is a common problem or it's just me? Any help on this matter would be appreciated. Also, is there any way to buy the "sticky material,'' in-between the front bezel and the bezel frame, that helps hold it down? If not, is there an alternative to that material? (i.e. some sort of two-sided tape)
Questa è una buona domanda?
1 Commento
Please check to see exactly which machine you are talking about. I don't believe you have the machine listed to the right, a MacBook Core 2 Duo. Sounds like a unibody machine.
da mayer
