no start up chime or display
I recently replaced a faulty power supply, when i try to turn it on, the fans come on and i can hear the hard drive spinning, but there is no start up chimes or display.
-FIXED- when my power supply went out, it did so during boot up, this corrupted the boot portion and somehow damaged one of my ram sticks, after replacing the power supply, i removed the bad stick (causing the no chimes) and put in a new hard drive and re-installed the os, it booted just fine. i was even able to get data off my old hard drive and reformat it to be an external drive.
--EDIT-- The ram was not damaged, was trying to use two ram from different manufactures. Needed to be two identical sticks.
Questa è una buona domanda?
4 Commenti
Thank you post mordum. I think i purchased your iMac on E-bay for parts not working. Thanks for clarifying the 1174 does not have LED lights-or does it?
da will
will, this question is 2 years old.
da oldturkey03
Will they all have the LED's but the view might be obstructed. See link in comment below.
da originalmachead
The problem was using two different ram sticks. I upgraded a mac book ram for a friend and tried using the two old sticks in this computer, they were same size but different manufacturers. Using either one and the computer worked booted, but both together caused problems.
da postmordum
