Salta al contenuto principale
ATV2 thinks it's on ethernet even when ethernet cable is unplugged
ATV2 keeps saying that "to switch to wifi, remove the ethernet cable". The ethernet cable is NOT plugged in yet ATV2 thinks its is.
Even when I plug an ethernet cable and sometimes configure the connection manually, it does not connect at all.
So with the ethernet cable plugged it does not work, and when unplugged, the ATV2 things it is plugged, hence no wifi! :-(
Any help please? Thanks guys
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You have a damaged ethernet port. Probably will have to replace the logic board. AS A WORK AROUND go to System Preferences:Network and remove (delete) the Ethernet Service. This may allow you to use only wireless or a USB Ethernet dongle.
If this answer was helpful please remember to return and mark it Accepted.
Punteggio 1
Aggiungi la tua risposta
Ibrahim Lahoud sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,534
