MacBook Pro Power Button Fix
Hi I apologize if this has already been answered, but I couldn't find it on this website. I bought a water damaged Macbook Pro 13 inch Mid 2010 from Ebay.I was able to start it through the power pads on logic board perfectly. Oddly though every single key on the keyboard worked and the trackpad also woks. The only thing that does not work is the power button. I have opened it up, cleaned underneath keyboard and logic board. The liquid indicators did not indicate any damage. I assume it was a very small spill on side of keyboard with power button. Put it back together and it will still start normally with power pads ( actually will only boost past apple logo sometimes... but I assume this is a hardrive issue because I'm using a HD from an old Macbook and I'm already replacing it with an SSD). It is my understanding that if the trackpad works, so should the power button. I can't do traditional PRAM or SMC resets without the use of the power button although I've tried.
My question is is there a way to do a hard SMC reset on the logic board ( like on older macbooks)? Or a way to fix power button. I know I should probably buy a new top case but, it seems like it may be an SMC issue and I'd like to try that first.
Thanks
Questa è una buona domanda?
