So, your trusty old MacBook isn’t quite what it used to be. Maybe the trackpad has slowed down a few paces—or maybe the battery is so swollen that it’s broken through the trackpad itself.
Or maybe—just maybe—an alien baby is hiding in your MacBook and it’s trying to escape!
The good news is that your MacBook battery woes can be solved with minimal expense and effort. The good-er news is that we just bundled up all the parts and tools you’ll need to swap out the battery yourself into one handy-dandy Mac Laptop Battery Fix Kit. Thousandsofpeople have already successfully replaced their laptop batteries using iFixit parts and guides. And since that sounds like a bunch of marketing hullabaloo, we’ll let their repair stories speak for themselves:
So there you have it—replacing the battery in your laptop is no big sweat. And to make things even easier on you, our Mac Laptop Battery Fix Kits are packed with all the parts and tools you need to make the swap. You can thank us later—just take care of that pubescent alien battery. Please.
Note: Swollen lithium-ion batteries can be dangerous if punctured and require careful care during removal. Read how to safely remove a lithium-ion battery from your device here.
I was freaking out when my old 2011 macbook pro battery started expanding, lifting my mouse pad up on one side and down on the other. The longer I waited the more it expanded. It was frustrating because the tracker worked but the mousepad couldn’t drag anything anymore. I feared having to spend $200 or more because of the age of my pro baby. Soooooooo glad I came across ifixit. Only problem was the tiny screwdriver couldn’t get one screw out so instead of 20 minutes it took me 1.5 hours to replace the battery. I was so nervouse the okd thing would explode in my face. I ended up just pulling the screw out with the cover. Then I forgot to leave that screw loose when I put it back in, so will have to struggle all over again when removing it again :(. Maybe a stronger screwdriver would help? Happy nonetheless…
Un commento
Alana C. - Replica
