Introduzione
The camera is attached to the motherboard in your phone. A T6 screwdriver is needed to access the camera.
Parti
Nessuna parte richiesta.
Press down the button on the back panel.
  • Press down the button on the back panel.
Aggiungi Commento
Push the back cover upwards. Push the back cover upwards.
  • Push the back cover upwards.
Aggiungi Commento
Remove the back cover from the phone. Remove the back cover from the phone.
  • Remove the back cover from the phone.
Aggiungi Commento
Press the silver button on the top of the phone.
  • Press the silver button on the top of the phone.
Aggiungi Commento
Pull the top of the case apart.
  • Pull the top of the case apart.
  • Slide thumbnail down the case seam to separate the rest of the case.
Aggiungi Commento
Gently pull the case apart.
  • Gently pull the case apart.
  • Careful! Do not to bend the plastic tabs.
Aggiungi Commento
Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture. Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
  • Using a T6 Torx Screwdriver, unscrew and remove the six screws shown in the picture.
Aggiungi Commento
Remove the panel that covers the motherboard. If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
  • Remove the panel that covers the motherboard.
  • If replacing the speaker, stop at this step and skip forward to the first step of the speaker guide.
Aggiungi Commento
Remove the LCD screen frame.
  • Remove the LCD screen frame.
Aggiungi Commento
Remove the motherboard.
  • Remove the motherboard.
Aggiungi Commento
Locate the camera on the circuit board.
  • Locate the camera on the circuit board.
Aggiungi Commento
Place the circuit board on a firm, static free surface (no cloth/carpet).
  • Place the circuit board on a firm, static free surface (no cloth/carpet).
  • NOTE: The circled alignment notch points to the left.
Aggiungi Commento
Pull the left holding tabs to the left.
  • Pull the left holding tabs to the left.
Aggiungi Commento
Lift out the left side of the camera.
  • Lift out the left side of the camera.
Aggiungi Commento
Pull the right holding tabs to the right.
  • Pull the right holding tabs to the right.
Aggiungi Commento
Pull camera off of board.
  • Pull camera off of board.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Job Jao
Membro da: 08/10/2010
37 Reputazione
2 Guide realizzate
Cal Poly, Team 3-27, Regan Fall 2010 Membro di Cal Poly, Team 3-27, Regan Fall 2010
CPSU-REGAN-F10S3G27
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,748
