Introduzione
it`s easy and very quick replacement. it could be completed even with fingerskate screwdriver, but i used simple philips 1,7 from my toolkit.
samsung sgh x820 samsung sgh x820 samsung sgh x820
  • samsung sgh x820
Aggiungi Commento
after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver. after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver. after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
  • after removing the battery, remove the five small Phillips-head screws with a #0 Phillips screwdriver.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
now we have two more screws hiden first time i used needle. this time i took a blade. removing the last two philipps-head screws.
  • now we have two more screws hiden
  • first time i used needle. this time i took a blade.
  • removing the last two philipps-head screws.
Aggiungi Commento
be carefull. the phone is thin and you should push on two hooks two open cover case.
  • be carefull. the phone is thin and you should push on two hooks two open cover case.
Aggiungi Commento
now you should take of the square metal  in the middle of your phone to eject display.
  • now you should take of the square metal in the middle of your phone to eject display.
  • i used plastic spudger
Aggiungi Commento
the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
  • the last step is to take of old lcd from main board. mine was easy to go, but probably it could be stuck with the glue and i recommend to use a blade carefully.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
sergeygraf
Membro da: 24/10/2010
161 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 997
