Introduzione
Is your device no longer holding a charge? Use this guide to replace a faulty or worn out battery.
Before disassembling your tablet, make sure it is powered off. Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around. Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
  • Before disassembling your tablet, make sure it is powered off.
  • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
Aggiungi Commento
Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off. At this point do not attempt to fully remove the battery as it is still attached to the logic board. At this point do not attempt to fully remove the battery as it is still attached to the logic board.
  • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
  • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
Aggiungi Commento
Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires. Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off. To ease reassembly, take note of which wire goes to the negative and positive terminals.
  • Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires.
  • Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off.
  • To ease reassembly, take note of which wire goes to the negative and positive terminals.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
calvin
Membro da: 21/01/2015
188 Reputazione
1 Guida realizzata
USF Tampa, Team 5-4, Brown Winter 2015 Membro di USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 941
