Salta al contenuto principale
iRobot looj 120 Rear Motor Replacement
Cosa ti serve
  1. iRobot looj 120 Rear Motor Replacement, Rear Motor: passo 1, immagine 1 di 1
    • Remove the four exterior screws
Conclusione
Joshua
Membro da: 10/24/14
631 Reputazione
6 Guide realizzate
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Membro di UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 Membri
7 Guide realizzate
Un commento
Yeah, to replace the motor just 4 screws and no parts required! Too easy, too easy to write an article that doesn’t help :( Is it just to sell a screwdriver? This would not improve your reputation. You’re wasting our time and wasting your time.
Description: Remove the 4 screws than anyone can see is a good start but did anyone been able to actualy open the body and access inside the box?
I do have an iRobot Looj 330. The body looks very similar to the other model in the range. There are 4 screws, yes but the body in 2 parts doesn’t open that easy. It’s waterproof, I believe there is a trick… Which?
Daniel B - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 249
