Salta al contenuto principale
iRobot looj 120 Front Motor Replacement
Cosa ti serve
    • To remove the auger simply pull it off
    • Then unscrew the four screws holding the plastic part in place
    • You can then pull that off revealing the piece that connects to the motor
    • The metal piece can now be replaced by inserting a new one
  1. iRobot looj 120 Front Motor Replacement, Removing Exterior Screws: passo 2, immagine 1 di 1
    • Remove the four exterior screws, and then the top plate.
    • Once the top plate is removed check the motors circuitry. Disconnect the motor and install the new motor.
Conclusione
Joshua
Membro da: 10/24/14
631 Reputazione
6 Guide realizzate
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Membro di UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 248
