Salta al contenuto principale
iRobot Roomba i6 Battery Replacement
Cosa ti serve
  1. iRobot Roomba i6 Battery Replacement, Remove the Bottom Cover: passo 1, immagine 1 di 3 iRobot Roomba i6 Battery Replacement, Remove the Bottom Cover: passo 1, immagine 2 di 3 iRobot Roomba i6 Battery Replacement, Remove the Bottom Cover: passo 1, immagine 3 di 3
    • Using your PH2 size screwdriver, remove the edge sweeping brush.
    • Using your PH2 size screwdriver, remove the 5 screws highlighted in the 2nd picture.
    • These top two screws highlighted in orange will unscrew completely if you keep going so be sure to stop unscrewing them as soon as you feel resistance.
    • Lift the bottom cover straight up off of the Roomba from the two spots the arrows are pointing to.
    Chiedi a FixBot
  2. iRobot Roomba i6 Battery Replacement, Remove the Battery: passo 2, immagine 1 di 1
    • Push the highlighted tab up while lifting the battery out of the Roomba.
    • During re-assembly, you just have to align the battery and push down until the tab clicks.
    Chiedi a FixBot
Conclusione
To install the new battery, follow these instructions in reverse order.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 61
Tutti i Tempi: 435
