Introduzione
Make sure you don't lose any screws! This guide has you unscrewing in a lot of spots so be careful!
Parti
Nessuna parte richiesta.
Remove the dust bin by pushing on the button for the dust bin removal Pull the dust bin out
  • Remove the dust bin by pushing on the button for the dust bin removal
  • Pull the dust bin out
Aggiungi Commento
Pull up on the silver handle to release the top protectant plastic Remove the top plastic carefully
  • Pull up on the silver handle to release the top protectant plastic
  • Remove the top plastic carefully
Aggiungi Commento
Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver. Pull the plastic bumper protector up and off of the bumper.
  • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
  • Pull the plastic bumper protector up and off of the bumper.
Aggiungi Commento
Flip the Roomba back over, so you are viewing the top. Pull up on the front bumper to remove it. Be careful not to pull too hard because there is wiring attached to the bumper.
  • Flip the Roomba back over, so you are viewing the top.
  • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
  • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
Aggiungi Commento
The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them Use your Phillips head #0 to remove the one - 7mm bottom center screw Use your Phillips head #2 to remove the two - 8mm screws by the handle
  • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
  • Use your Phillips head #0 to remove the one - 7mm bottom center screw
  • Use your Phillips head #2 to remove the two - 8mm screws by the handle
  • Push down the two release points to pull the plastic piece up
  • Pull the plastic piece up
Aggiungi Commento
Conclusione
Rhett
Membro da: 22/01/2015
890 Reputazione
7 Guide realizzate
Cal Poly, Team 21-20, Maness Winter 2015 Membro di Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 304
