Introduzione
You will be removing the front bumper (this runs into objects and walls) from the Roomba to gain access to the control center (display) and motherboard.
Parti
Nessuna parte richiesta.
Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver. Pull the plastic bumper protector up and off of the bumper.
  • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
  • Pull the plastic bumper protector up and off of the bumper.
Aggiungi Commento
Flip the Roomba back over, so you are viewing the top. Pull up on the front bumper to remove it. Be careful not to pull too hard because there is wiring attached to the bumper.
  • Flip the Roomba back over, so you are viewing the top.
  • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
  • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
Aggiungi Commento
Conclusione
Rhett
Membro da: 22/01/2015
890 Reputazione
7 Guide realizzate
Cal Poly, Team 21-20, Maness Winter 2015 Membro di Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 593
