Introduzione
It is recommended to empty and clean the dust bin often. This will keep your Roomba at its peak performance.
Grasp the back of the Roomba
  • Grasp the back of the Roomba
  • Push the button with your thumb
  • Remove the dust bin by simply pulling out
  • Be careful not to pull to hard as not to have dust/dirt fall out.
Aggiungi Commento
To open the gate, push the yellow tab and pull it open Push in the two yellow tabs on the filter and pull it out gently Push in the two yellow tabs on the filter and pull it out gently
  • To open the gate, push the yellow tab and pull it open
  • Push in the two yellow tabs on the filter and pull it out gently
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Matt Davis
Membro da: 22/01/2015
1.083 Reputazione
7 Guide realizzate
Cal Poly, Team 21-20, Maness Winter 2015 Membro di Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 835
