Salta al contenuto principale
iRobot Roomba 655 Pet Series Display Replacement
Cosa ti serve
  1. iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: passo 1, immagine 1 di 2 iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: passo 1, immagine 2 di 2
    • Remove the dust bin by pushing on the button for the dust bin removal
    • Pull the dust bin out
  2. iRobot Roomba 655 Pet Series Display  Replacement: passo 2, immagine 1 di 2 iRobot Roomba 655 Pet Series Display  Replacement: passo 2, immagine 2 di 2
    • Pull up on the silver handle to release the top protectant plastic
    • Remove the top plastic carefully
  3. iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: passo 3, immagine 1 di 2 iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: passo 3, immagine 2 di 2
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  4. iRobot Roomba 655 Pet Series Display  Replacement: passo 4, immagine 1 di 3 iRobot Roomba 655 Pet Series Display  Replacement: passo 4, immagine 2 di 3 iRobot Roomba 655 Pet Series Display  Replacement: passo 4, immagine 3 di 3
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
  5. iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: passo 5, immagine 1 di 3 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: passo 5, immagine 2 di 3 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: passo 5, immagine 3 di 3
    • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
    • Use your Phillips head #0 to remove the one - 7mm bottom center screw
    • Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • Push down the two release points to pull the plastic piece up
    • Pull the plastic piece up
  6. iRobot Roomba 655 Pet Series Display  Replacement, Display: passo 6, immagine 1 di 3 iRobot Roomba 655 Pet Series Display  Replacement, Display: passo 6, immagine 2 di 3 iRobot Roomba 655 Pet Series Display  Replacement, Display: passo 6, immagine 3 di 3
    • Pull the silver tab, and clear tinted display off
    • Remove the 4 - 9mm screws holding the display with your Phillips head #0
  7. iRobot Roomba 655 Pet Series Display  Replacement: passo 7, immagine 1 di 3 iRobot Roomba 655 Pet Series Display  Replacement: passo 7, immagine 2 di 3 iRobot Roomba 655 Pet Series Display  Replacement: passo 7, immagine 3 di 3
    • Remove the display
    • Remove the plastic protectant film from the motherboard
Conclusione
Rhett
Membro da: 01/22/15
1.329 Reputazione
7 Guide realizzate
Cal Poly, Team 21-20, Maness Winter 2015 Membro di Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 864
