Salta al contenuto principale
iRobot Roomba 595 Pet Series Side Brush Motor Replacement
Cosa ti serve
  1. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Secondary Brush: passo 1, immagine 1 di 1
    • Flip the Roomba upside down. Using the Phillips #0 screwdriver, carefully remove the 5 mm screw holding the brush in place.
  2. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: passo 2, immagine 1 di 1
    • Gently pull the brush up and remove it from the device.
  3. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: passo 3, immagine 1 di 2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement, Side Brush Motor: passo 3, immagine 2 di 2
    • Unscrew the four 10mm screws on the underside of the Roomba with a Phillips #1 screwdriver.
    • Lift the external underside cover accordingly.
  4. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #0 screwdriver bit to remove the three 15mm screws.
  5. iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: passo 5, immagine 1 di 2 iRobot Roomba 595 Pet Series  Side Brush Motor Replacement: passo 5, immagine 2 di 2
    • Remove the motor from the blue casing.
Conclusione
USF Tampa, Team S10-G5, Thompson Fall 2017 Membro di USF Tampa, Team S10-G5, Thompson Fall 2017
USFT-THOMPSON-F17S10G5
3 Membri
10 Guide realizzate
2Commenti sulla guida
I changed the motor and still does not work.
Jose - Replica
I changed the motor and still did not work.
Jose - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 919
