Salta al contenuto principale
iRobot Roomba 551 Bumper Sensor Replacement
Cosa ti serve
  1. iRobot Roomba 551 Bumper Sensor Replacement, Side Brush: passo 1, immagine 1 di 1
    • Place your Roomba upside-down on a hard surface.
  2. iRobot Roomba 551 Bumper Sensor Replacement: passo 2, immagine 1 di 1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551 Bumper Sensor Replacement: passo 3, immagine 1 di 1
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551 Bumper Sensor Replacement, Bottom Plate: passo 4, immagine 1 di 1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551 Bumper Sensor Replacement: passo 5, immagine 1 di 2 iRobot Roomba 551 Bumper Sensor Replacement: passo 5, immagine 2 di 2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551 Bumper Sensor Replacement: passo 6, immagine 1 di 1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551 Bumper Sensor Replacement, Bumper: passo 7, immagine 1 di 3 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: passo 7, immagine 2 di 3 iRobot Roomba 551 Bumper Sensor Replacement, Bumper: passo 7, immagine 3 di 3
    • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
  8. iRobot Roomba 551 Bumper Sensor Replacement: passo 8, immagine 1 di 1
    • Lift the bottom cover and set it to the side.
  9. iRobot Roomba 551 Bumper Sensor Replacement: passo 9, immagine 1 di 2 iRobot Roomba 551 Bumper Sensor Replacement: passo 9, immagine 2 di 2
    • Flip the Roomba over, grasp the bumper, and gently lift to remove.
    • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
  10. iRobot Roomba 551 Bumper Sensor Replacement, Bumper Sensor: passo 10, immagine 1 di 1
    • Flip the Roomba so that the bottom is facing you.
  11. iRobot Roomba 551 Bumper Sensor Replacement: passo 11, immagine 1 di 2 iRobot Roomba 551 Bumper Sensor Replacement: passo 11, immagine 2 di 2
    • Remove the two 5mm screws located near the center of the bumper using a Phillips #1 screwdriver.
  12. iRobot Roomba 551 Bumper Sensor Replacement: passo 12, immagine 1 di 1
    • Pull gently on the bottom of the sensor to remove.
  13. iRobot Roomba 551 Bumper Sensor Replacement: passo 13, immagine 1 di 3 iRobot Roomba 551 Bumper Sensor Replacement: passo 13, immagine 2 di 3 iRobot Roomba 551 Bumper Sensor Replacement: passo 13, immagine 3 di 3
    • Flip the bumper over and lift the sensor from its compartment.
    • You are now free to replace the bumper sensor.
Conclusione
Altre 4 persone hanno completato questa guida.
Cody Rhoads
Membro da: 01/16/14
348 Reputazione
2 Guide realizzate
Cal Poly, Team 13-14, Regan Winter 2014 Membro di Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 Membri
19 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 4,668
