Introduzione
This guide is fairly easy. It requires no tools and will only take about 5 minutes.
Lay the Roomba on a flat surface with the red side up.
  • Lay the Roomba on a flat surface with the red side up.
Aggiungi Commento
Push in the red, gumdrop-shaped button with your thumb. While holding in the button, slide the back piece away from the main body of the Roomba.
  • Push in the red, gumdrop-shaped button with your thumb.
  • While holding in the button, slide the back piece away from the main body of the Roomba.
Aggiungi Commento
Flip the back piece over in your hand. Using your other hand, grab the yellow tab and pull it away from the back piece. Using your other hand, grab the yellow tab and pull it away from the back piece.
  • Flip the back piece over in your hand.
  • Using your other hand, grab the yellow tab and pull it away from the back piece.
Aggiungi Commento
Pinch the black plastic of the filter and pull it away from the yellow filter holder. Pinch the black plastic of the filter and pull it away from the yellow filter holder. Pinch the black plastic of the filter and pull it away from the yellow filter holder.
  • Pinch the black plastic of the filter and pull it away from the yellow filter holder.
Aggiungi Commento
Conclusione
Samantha Barrett
Membro da: 13/01/2014
501 Reputazione
5 Guide realizzate
Cal Poly, Team 17-5, Forte Winter 2014 Membro di Cal Poly, Team 17-5, Forte Winter 2014
CPSU-FORTE-W14S17G5
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 387
