Introduzione
Removing the brush guard will be easy. It won't take more than 5 minutes to complete and no tools are required.
Lay the Roomba upside down on a flat surface with the blue strip away from you.
  • Lay the Roomba upside down on a flat surface with the blue strip away from you.
Aggiungi Commento
Use your index fingers to pull the yellow tabs towards you. While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
  • Use your index fingers to pull the yellow tabs towards you.
  • While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
  • For reassembly, make sure to push in the brush guard until it clicks into place.
Aggiungi Commento
Pull back the brush guard to unhook it from the latches.
  • Pull back the brush guard to unhook it from the latches.
  • Remove the brush guard by lifting it up and out of the Roomba.
  • This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
Aggiungi Commento
Conclusione
Samantha Barrett
Membro da: 13/01/2014
501 Reputazione
5 Guide realizzate
Cal Poly, Team 17-5, Forte Winter 2014 Membro di Cal Poly, Team 17-5, Forte Winter 2014
CPSU-FORTE-W14S17G5
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 290
