Salta al contenuto principale
iRobot Roomba 4100 Battery Pack Replacement
Cosa ti serve
  1. iRobot Roomba 4100 Battery Pack Replacement, Battery Pack: passo 1, immagine 1 di 1
    • Turn the Roomba upside down to be able to see the yellow battery pack.
  2. iRobot Roomba 4100 Battery Pack Replacement: passo 2, immagine 1 di 2 iRobot Roomba 4100 Battery Pack Replacement: passo 2, immagine 2 di 2
    • Remove the battery by placing your fingers into the two holes and firmly press your fingers against both sides of the battery.
    • Lift the battery directly up and out of the device.
  3. iRobot Roomba 4100 Battery Pack Replacement: passo 3, immagine 1 di 1
    • Line up the replacement battery’s larger tab side with the larger tab hole and the smaller tab side with the smaller tab hole.
    • Insert the replacement battery into the empty space and firmly press down onto the battery until two audible clicks are heard.
Conclusione
Your iRobot Roomba 4100 is now ready for use.
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 20-6, Maness Fall 2010 Membro di Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
2 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 20
Tutti i Tempi: 8,385
