Introduzione
Replace the electronic portion of the control buttons.
Cosa ti serve
Remove the single 2.1 mm Phillips screw securing the logic board to the front case.
Remove the following four screws:
Two 1.2 mm Phillips screws with large heads.
Two 1.6 mm Phillips screws with small heads.
Altre 7 persone hanno completato questa guida.
2 Commenti
I'm gonna try to remove the back cover with minimal prying to reduce cosmetic defects. The plan is to somehow remove the spring loaded clip by pushing out the lever pin, then drilling holes along the edge of the over wherre the 3 little hooks are (In this image, where the right thumb is touching. https://d3nevzfk7ii3be.cloudfront.net/ig...).
It would be great if someone could provide a closer look at where exactly the hooks are so I can position my 1.5mm drill bit better. Also, if you can to figure out how to remove the spring loaded clip mechanism without going through the 4 screws, that'd be awesome! I suspect the pin is held in place by just adhesive, but don't want to risk pushing too hard and causing defects. :(
just open the clip past where it is suppose to open and it pops right off.
