Introduzione
Replace the rear case on your iPod shuffle for a shiny new clip.
Parti
Nessuna parte richiesta.
Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
  • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
  • Be careful when using a metal spudger, as you may scratch the outer case.
Aggiungi Commento
Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case. Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
Aggiungi Commento
Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
  • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
  • Pry the rear case away from the front case.
Aggiungi Commento
Lift the bottom of the rear case and remove it from the rest of the iPod.
  • Lift the bottom of the rear case and remove it from the rest of the iPod.
Aggiungi Commento
Conclusione
Matthew Newsom
Membro da: 05/01/2010
31.287 Reputazione
93 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 31
Tutti i Tempi: 6,226
